fairing cam bolt, plastic rivets
Old Jul 3, 2007 | 01:27 PM
thecannibalchef's Avatar
Default fairing cam bolt, plastic rivets
i lost the cam bolt that holds the top of the right fairing to the stay in front of my knee. the left cam bolt has a little plastic washer on the back that keeps it from falling out, but the right one does not, and i undid it and forgot about it. where can i get one of these, and one of the plastic washers so if i make that mistake again, i can just go back and tighten it later?
also, i want to replace all those little push-in phillips head plastic rivets that hold the lower fairing, as well as assorted junk in the intake tract, together. i don't want phillips head ones, but i want them to be secure and snug. i've got 2 types right now, both of which are phillips head, but some of which can be pushed out from the back, making them easier to remove. the push-out kind do not keep the plastic very tight. have any of you found a good solution to these things? and where can i pick about 20 of these up? i want to replace all of them at the same time.
Old Jul 4, 2007 | 11:36 PM
bmg velocity's Avatar
Default RE: fairing cam bolt, plastic rivets
Those are what is known as self-retaining and are usually very high quality in the fit and finish dept.
Poor mechanic skills leads to calls to an OEM or special parts dealer.
Old Jul 4, 2007 | 11:39 PM
$5 at the honda shop. this time, i'm getting a nylon washer for the back of it like the other side has. please don't confuse poor mechanic skills with a short attention span.
VWW8
May 19, 2012 03:31 PM
DRam
May 4, 2008 01:20 PM
143MYCBR
Feb 20, 2008 04:05 PM
joker
Jul 26, 2006 09:47 AM
