F4i guage help
Need some help with my guages. Theystopped working out of nowhere. The clock works and the lights work - everything else is dead. The guage display doesnt light up either. I checked the connections and there all good. Anyone have any ideas here? Appreciate any help. I like having my guages working. Thanks. Oh - I'm eventually gonna hook em up to someone else's bike to see if they work but until then just looking for some ideas. Thanks.
Take the cluster out, and where the wire harness goes into the back of the cluster, there's a little black cover with 2 screws. Take that cover off, and the harness splits into 2 small flat connectors and plugs onto the printed circuit board. I'll bet one of those is partially unplugged, and sitting crooked instead of being pushed all the way in. Did you try wiggling the harness all around to see if anything changes?
Same thing was happening with my gauges. Do what Jared says... He did that to my gauges and they worked fine. If anything has been pulling on the harness, it can come partially unplugged from inside the cluster.
Thanks for posting up. I already tried that and it still doesnt work. I'm gonna connect my guages to one of my boys bikes and see if they work or not and then go from there. If anyone else has any suggestions, I'd appreciate it. Thanks.
