F4i fuel pump works but...
Old May 9, 2015 | 04:28 PM
ChiemyChanga's Avatar
Default F4i fuel pump works but...
I have a 2002 F4i with 1300 miles on it. I took apart a lot of the wires after an accident, and when I put it all back together the fuel pump stopped turning on.
So I jumped the fuel pump relay in the farthest rear right and the fuel pump works (Continuously whines but will not help me start the bike).
I leave that fuel pump on and check the headlights (stopped working just now I have no idea why, but gets 12v), turn signals, brake lights, they all work.
When I hit the killswitch to off, the fuel pump turns off.
When I kick the bike in first gear (kickstand down), the kickstand safety function doesnt allow the bike to turn over.
I leave it in first gear but now put the kickstand up and the bike turns so the clutch Sensor works.
I have no idea what to do now. Anything would help guys. Thanks.
Old May 9, 2015 | 04:52 PM
74demon's Avatar
Make the headlight work and your fuel pump should work too. The BAS runs through the headlight and will stop the pump from working.
Old May 9, 2015 | 05:33 PM
But when the headlight was working, the fuel pump still wouldnt prime...how do i get the headlight to start working again?
Old May 9, 2015 | 05:48 PM
74demon's Avatar
It depends on why the light isn't working....
Have you tried bypassing the BAS?
Old May 9, 2015 | 06:05 PM
Yes i forgot to mention that I jumped the two outside wires for the BAS.
Old May 9, 2015 | 06:27 PM
74demon's Avatar
Oh.... In that case, you will need to get out the wiring diagram and start tracing circuits. Could be anything after an accident....
Old May 9, 2015 | 08:10 PM
How do I get the headlight to start working again? And Im not sure what to do...Im checking for continuity from the fuel pump to the rest of the circuit?
Old May 10, 2015 | 03:08 PM
So I just tested the engine cut off relay, headlight relay, fuel cutoff relay, and they all work and pass the test (click on the coils, then continuity on the other leads). I checked continuity on the front harness where the headlights connect. I just checked the bulb that was working two days ago until it stopped, and I see inside the filament that its disconnected so I need to replace the headlight.
Can my fuel pump turn on without the headlights? Or does it turn it off?
Kopi Ko
Sep 6, 2024 12:02 AM
Raptor5150
Jul 31, 2012 05:26 AM
Chris07
Mar 2, 2009 09:54 AM
zblad
Dec 5, 2008 01:14 AM
