F4 questions... weird sounds.
the gear box?... while im cruising in 6th...and come up to a light.... i usualy down shift one by one and blip the throttle... etc
but sometimes... when there isnt much distance... and i use the brakes... and between like 20mph-0... i just hold the cluthc... and go down the gears all the way to first. but when i reach first.... there is a little... winding noise.... no throttle , didnt let go of the clutch. is this normal?
some times when changing gears during normal operation... it clunks somewhere... and makes a really loud ratteling noise... and id have to hit the lever again to make it fall into gear.... and its NOT from 1-2nd so... its not neutral.
if i live in FL... what would be the best type of coolant to get?... i dont have to worry about antifreeze and such right?... since the ABSOLUTE lowest it will get is probably 35degrees once in a bluemoon.
can the CCT rattle be at 2 differnt RPM;s in the rev range?.... i hear slight rattle from 3-4k and then a realy faint one at like 5-6k
Santos4288
01-03-2012 11:14 PM
DevilInDisguise
02-23-2011 04:42 PM
