F4 dies for 10 minutes
Old Jul 30, 2012 | 06:25 PM
justasquid's Avatar
First thought would be the fuel is being vacuum locked. Next time it happens, quickly pop open your gas cap and listen for a whoosh sound. If you get this, it means the tank vent is blocked.
Also, some models (Im not sure on yours) have coolant that flows through the carb bodies for cold weather riding. If your bike has this and its open, you may want to close it during warm weather riding.
Also would be a good time to check the charging system. Many times, the ignition will act up during warm conditions. Check to make sure you have spark next time it happens. Also check your battery voltage to make sure its not too high or too low once the bike is warmed up. Do this at idle and at 4,000 rpms once the bike is warmed up.
Old Jul 30, 2012 | 06:48 PM
MadHattr059's Avatar
I'm gonna vote on the r/r-charging system being the issue.
Check these links, they give you the low-down. Heck, even if it's not the issue..
Having a clean bill of health for the electrical system is a step ahead.
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Technical Resources - Resources for Electrical Systems on Motorcycles and ATVs - ElectroSport
Hope this helps, Ern
bumblb
Jun 2, 2018 07:00 PM
raz478
Nov 21, 2013 08:49 AM
ecd2004
F2 Tech
May 1, 2010 05:04 PM
Mstngdrew232
May 4, 2007 11:49 PM
hondaluvR
Jan 18, 2006 12:13 AM
