F3 wont drive
98 cbr f3 will idle allllll day long but if i go to ride it it just bogs i have new filter pump and cut relay in it and tue vent is clear and im getting fuel flow. im so stumped here guys any input would be greatly apreciated. is their a load sensing device of sorts that can cause it to do this.? i can revv it out as much as i want and no probleme...i need help bad
[QUOTE=87turbobuick;1245003]98 cbr f3 will idle allllll day long but if i go to ride it it just bogs i have new filter pump and cut relay in it and tue vent is clear and im getting fuel flow. im so stumped here guys any input would be greatly apreciated. is their a load sensing device of sorts that can cause it to do this.? i can revv it out as much as i want and no probleme...i need help bad
Take out 2 of the four spark plugs and look at what color they are. From there you can get an idea of whats going on.
ok i yanked my carbs off and they were spotless...cleaned them anyway battery was dead so i just jumped it real quick ...bike did great for 100 miles battery charged up ajd everything....she sat overnight and i rode her 30 miles today no probleme...parked it for a lil then went back to ride ajd same issue...it just bogged and cut out....battery was still strong but it fired up when i hit the choke and then i got another couple hundred yards ajd turned around and she cut out...and i cranked and cranked until i killed the battery....what could be happening....im seriously out of ideas...could i be looking at maybe a solenoid for the ram air being messed up or something? all the lines are hooled up ajd good so im just completely out of ideas besides selling the bike whoch i do not want to do :'(
sounds like electrical. loose connection somewhere. My F4I did it after a wreck and I just went through all the connections checking wires and cleaning plugs, adding di-electric grease. I still dont know what or where the issue was but after i finished the entire harness she purred like always.
