experience help needed!
Hello all, first off let me say thanks. Let me get too it, I wreck my 04 cbr f4i. and i need help on rebuilding it. im posting up pictures for anybody to help identify what parts i need. if so can you name the prices for each part and good website to get it? savage/used/new
i just want it to be up and running again, i miss it. so im not really worry about cosmetic.
if anybody need more pictures or even a thorough video then i will get it asap. tho my bike is not with me at the moment.
thanks again...
please contact asap
thanks again...
please contact asap
Like all the other post this bike is too far gone. It will cost you a lot more time and money to repair it than to get a new bike. Take the insurance money if you have insurance and if not cut your losses. Glad your still here to talk about it.
hey, i'm all for fixing stuff... bringing it back from the dead...
but damn... i'd thank god you're still here after that wreck, and look for another bike. the motor looked "okay" and the frame and forks are a "maybe". the subframe - i can't tell if it's bent or not - definitely looks a lil rashed.
motor - you'd probably need at least a new oil cooler... maybe a new side cover for the stator and clutch. could need a new bottom oil pan (can't really see all the damage when its all piled up together). i'm sure the radiator is bent and probably done. that's as far as i could see
new exhaust
new swingarm
new rear wheel, axles, hub, spacers, sprocket, etc.
new chain
new rearsets
new fairings
new tank
new clip-ons, perches, levers,
new airbox tubes
new headlight
and that's just to get the thing rideable.... who knows what else is wrong. the frame might be bent - in which case you won't want to ride it. this wasn't a little get-off - ever aspect of the bike is affected
this one is one you should just let go.... you'd probably find a whole other used bike for cheaper than what replacement parts would cost all together.
new exhaust
new swingarm
new chain
new rearsets
new fairings
new tank
new airbox tubes
new headlight
ouch.....I am also in for fixing things, but at this point, you will be paying more on parts to get it up running than what you will spend on buying another bike. Let alone the time you will have to spend on finding parts. Unless this bike has some VERY SPECIAL sentimental values to you, (admit it, we all get attached to our bike), then I would definitely consider getting her fixed, otherwise...I'd walk away from it and get yourself a safer bike. Anyway, It is just my opinion.
