Engine turned when I tightened main bolt on flywheel
Old 03-03-2019, 09:10 PM
Bobcobb's Avatar
Default Engine turned when I tightened main bolt on flywheel
I'm rebuilding my 2001 cbr929rr and when I was replacing my stator, the engine moved when i torqued the main flywheel bolt. Does anyone know if this will cause a problem?
Old 03-03-2019, 09:54 PM
74demon's Avatar
Why did you touch that bolt when replacing a stator? The stator is mounted on the cover.
The motor turning is not a problem at all.
JankCibberf2
F2 Tech
07-18-2012 12:00 AM
stevens09
06-12-2012 05:29 PM
F4i
06-28-2009 11:41 PM
wiyo120
09-04-2008 08:11 PM
tone.
04-22-2008 10:15 PM
Quick Reply: Engine turned when I tightened main bolt on flywheel
