Engine turned when I tightened main bolt on flywheel
I'm rebuilding my 2001 cbr929rr and when I was replacing my stator, the engine moved when i torqued the main flywheel bolt. Does anyone know if this will cause a problem?
Why did you touch that bolt when replacing a stator? The stator is mounted on the cover.
The motor turning is not a problem at all. |
