Engine Rattle
Old 10-13-2006, 05:47 PM
Tahoe SC's Avatar
Default RE: Engine Rattle
do some searches...you can mod the OEM so it doen't get all loose and make noise.
one thing you can do is flare or change the pin located at the tip of the cctl. this will get rid of noise from the rattling. second, you can would the spring inside the cctl once or twice to give it some more tension.
also, the OEM cctl actually does have a manual function...if you take off the bolt at the rear of it and then stick a small flathead driver in there and turn counter clockwise, it actually extends the tip of the cctl!
note, the cctl is designed not to back out...so it can only go forward...
Old 10-13-2006, 06:51 PM
Err's Avatar
Err
Err is offline
tahoe, you're such a wealth of information.
Old 10-13-2006, 06:52 PM
Tahoe SC's Avatar
AND I DO POWER WHEELIES LIKE A BAD BOY!!!!!!!!!!!!!!!!!
Old 10-13-2006, 10:48 PM
Bobthebiker's Avatar
it seems like the CCT rattle is a CBR trademark isnt it? been in em since the 600 hurricanes came out.
Old 10-14-2006, 05:15 AM
yep, its one of those things, i have a '77 cb750F1, and they are notorius for the HIVO chain rattle..... *shrug*, spose it gives us something to complain about...
peace
Old 10-14-2006, 10:42 PM
KidCr3nshaw's Avatar
There's really no reason to keep the OEM tensioner in the bike, in all honesty. We all know it's going to start losing it's tensioning ability, so screw it.
Buy the $50 part and replace it now.
Old 10-15-2006, 02:30 PM
Tahoe SC's Avatar
there are pluses and minuses to both parts...so don't clown either one.
if you study the part and take a look at the design, you can correct the flaws yourself.
OEM can adjust like a manual.
Old 10-15-2006, 07:05 PM
snowboarding82's Avatar
My buzzing noise sounds like it's coming from the dash?
Mike
Old 10-16-2006, 12:47 AM
Tahoe SC's Avatar
likely your cluster of keys mang! !
Old 10-16-2006, 11:57 AM
joesrods's Avatar
Thanks for all of the info, Tahoe is there anyway that you can post a pic of the CCT and the actual screw that you are talking about? I do not even know what the CCT looks like! Thanks
Quick Reply: Engine Rattle
