ENGINE NUMBERS ?
Old Nov 20, 2008 | 02:11 AM
HASS's Avatar
Default ENGINE NUMBERS ?
Hi Chaps,
I am hoping someone can help, I have a pair of engines which I am fitting into the rear of an Autograss special, I believe they are CBR engines of some spec or other.
They have been used together before in a similar car and have been Dynojetted together by PRS in Lincoln.
The engine numbers are SC09E and SC21E.
Any info on exactly which bike(s) these are out off would be greatly appreciated to help source parts.
Cheers in advance
Old Nov 20, 2008 | 02:58 AM
Hurricane rider's Avatar
Default RE: ENGINE NUMBERS ?
look on the right side of the cylinder block, usually either the side or maybe the front, toward the bottom of the cylinders themselves, you'll see a number such as 598cm or something similar, which designates the displacement of the motor. 598cm is a 600cc engine, essentially what they do is take a motor of a given size and round it up to 250, 400, 500, 600, 750 900 1000 etc. its much easier than saying its a 997cc motor, or 748cc engine in your bike. you know?
Old Nov 20, 2008 | 03:10 AM
HASS's Avatar
Thanks for that info, I know they are 998s but I am not sure exactly what model they came out of, and i really need to know that to get some parts and a wiring diagram.
Old Nov 20, 2008 | 07:39 AM
justasquid's Avatar
they are both CBR 1000F engines. The SC09E engine is from a 1989-1994 model. The SC21E is from a 1987-1988 model.
Old Nov 20, 2008 | 08:37 AM
HASS's Avatar
Thanks buddy, that was exactly what i wanted to know, you dont happen to have a wiring diagram for the engines do you as i need to wire up this pair into my race car !!!
Cheers again, Hass
oldschoolsdime92
May 19, 2021 05:56 PM
psx2rulz
Jul 7, 2019 08:04 PM
rabbitae86
Aug 2, 2011 07:51 PM
jwp6114
Oct 7, 2007 08:07 AM
TimBucTwo
Aug 16, 2006 09:16 PM
