Drippy carbs
Old Apr 5, 2009 | 02:55 PM
bosshaus1's Avatar
Question Drippy carbs
1993 cbr 900rr
carbs cleaned, repaired, and adusted as needed by mechanic.
new plugs
new battery
The bike starts. After about 15 seconds the carbs drip gas at the float bowl cover. Please tell me what you guys think and what I need to do?
Thanks
brian
Old Apr 5, 2009 | 07:18 PM
justasquid's Avatar
does it drip at the seam where the float bowl connects to the main body of the carb?
Or does it come out of the overflow on the side of the carb?
is it on all carbs?
A few things may be happening.
1. the mechanic forgot to tighten the float bowl and the screws are only snugged up.
2. the mechanic forgot to use a new gasket, or the gasket is misaligned and is causing the leak.
3. the mechanic improperly adjusted the floats and they are set too high. or, the clip that connects the float to the needle is not placed correctly. Its also possible that the mechanic could have just bumped the float by mistake. it doesnt take much to bend them.
either way, I think the mechanic that worked on it needs to fix what ever happened.
Old Apr 6, 2009 | 09:55 PM
bosshaus1's Avatar
He already has them back. Thanks for the help
F4Fighter
Apr 1, 2015 06:54 AM
Dylan4380
F2 Tech
Jan 11, 2011 02:38 AM
sas1810
Apr 26, 2008 11:10 PM
ewok
Jun 1, 2006 04:41 PM
