Drill Inserts for Spools not working
Old Feb 27, 2007 | 05:27 PM
Leveltwo's Avatar
Default Drill Inserts for Spools not working
i drilled the spool hole and inserted the metal insert for a 8mm bolt, and when i try to tighten the spool, the insert just spins, i think i have to somehow "pull in" the insert to clamp it onto the swingarm, but i dont know how..any sugesstions?
Old Feb 27, 2007 | 05:59 PM
Triax's Avatar
Default RE: Drill Inserts for Spools not working
Your suppossed to drill it large enough that it fits in snuggly. Then it expands as you screw the tool into it. You may have drilled the hole to big.
Old Feb 27, 2007 | 06:04 PM
Leveltwo's Avatar
i never got the tool, know where to get one from?
Old Feb 27, 2007 | 07:22 PM
Triax's Avatar
You should be able to thread something into it, so that it will expand and grab the metal.
Old Feb 27, 2007 | 11:54 PM
Demon RR's Avatar
use a slightly larger thread insert and spool bolt. this should work and with minimal cost.
Old Feb 28, 2007 | 01:19 AM
Jason748's Avatar
The one time I've had to do this this is what worked best for me...
But I would highly recommed instead of doing this, have a local welding shop weld a piece of bar stock to the underside of your swingarm (like on the cbr600rr) that you can drill and tap for teh correct size thread. It's a much better way to do it.
Thread a hex nut onto a 8mm hex headed bolt.
Place a washer onto the bolt.
Thread the bolt about 1/2 way, maybe a little more into the threaded insert.
Thread the nut down so it's just touching the insert.
Put the threaded insert (with the nut and bolt in place) into your drilled hole.
Using two wrenches, one to hold the bolt in place and one to start tightening down the nut to compress the threaded insert.
Old Feb 28, 2007 | 02:39 AM
Leveltwo's Avatar
if i put a nut on the inside of the swingarm, then i cant hold it to tighten it...
Old Feb 28, 2007 | 12:32 PM
Triax's Avatar
Check this "how" to out.
http://cbrworld.net/forums/thread/140623.aspx
Old Feb 28, 2007 | 01:30 PM
Leveltwo's Avatar
yea, that is the tool i need...i think i know what Jason is talking about now, im gonna try that...thanks for the help
Old Feb 28, 2007 | 07:26 PM
Leveltwo's Avatar
ok, got it...used the bolt technique...worked good, i had to put a starwasher to keep it from spinning
f3racer
Dec 28, 2008 06:31 AM
n_vanexel31
Sep 26, 2008 01:10 PM
Rod Dog
Oct 22, 2006 02:19 PM
02cbrf4i4u
Aug 4, 2006 09:53 AM
