Does this brake hose look bulged to you?
Old Jun 17, 2020 | 05:35 PM
tommytwoshoes's Avatar
Default Does this brake hose look bulged to you?
This is my F4's rear brake hose. I have two questions here;
Is that bulge just after the banjo normal or should I get a new one?
Is there any advantage to buying a rubber line instead of braided? I mean, might the slight amount of give be just enough to help prevent lockup in a panic?
Old Jun 17, 2020 | 06:40 PM
Doc Samson's Avatar
The bulge looks to be a natural flare from it going over the metal of the banjo although mine isn't quite that pronounced. If it doesn't have cracks in it from dry rot, it should be fine but certainly won't hurt to replace if you are feeling a bit sketched out...
As for braided vs. rubber, on the rear brake I see zero advantage to using braided other than as "flair" or, possibly, longevity. That being said, I don't have any experience with braided lines and am still running my stock rubber lines. I try to practice emergency braking on the regular and have yet to reach a point where I feel like my braking ability has surpassed what the brakes can do at full squeeze. YMMV...
mnguyen84
F4i - Wanted
Apr 23, 2012 02:40 PM
dvdtsan
Jan 24, 2009 07:02 PM
cwmc29
Apr 13, 2007 04:42 PM
jjm82
Sep 5, 2006 01:44 PM
