Digital Speedometer problem
Hello, I'm new here. can someone help me in my problem regarding my digital speedometer, sometimes it works but sometimes it just reads 0 even though I'm moving. I had it checked in a mechanic and he said that i have to replace the speed sensor. Is there anything i can do or is it just in the wiring? thank you and please email me (celepano@yahoo.com) if you have an answer, thank you.
do you have a service manual for the bike? If not, you can download one for free.. from where, I don't remember, but if you do a search I'm sure you can find it. Take a look at that. Determine if it's something you think you may be able to do. These jobs are usually easier than you would think.
What bike is it on? Usually, the speed sensor is located on or near the front drive sprocket cover. It would be a simple unplug and swap sensors.
but before you replace. try cleaning the surface. A lot of times, gunk gets built up on the surface of the sensor and it will work intermittenly or read incorrectly..
Its on my cbr 600f4i 2002 model, the mechanic has cleaned the sensor,it worked but when i went home it started to fail again, is there anything else that i have to check or clean or plug and unplug?
thank you
thank you
I can't answer for justasquid but my guess is that you're going to just need to try a replacement and see if it works, it is the lessor of two evils if you are comparing a speed sensor problem to a guage cluster problem.
Check if your sprockets have the same amount of teeth as stock. I heard that can cause this problem. I had the same issue and I bought a chain and sprocket kit with stock gearing, installed it, disconnected then reconnected the battery and haven't had the problem since.
if his worked and then didnt after a clean, sounds like something faulty in the wiring or a bad sensor
I had to replace mine a few years ago (I also have a 01 600, but it's an F4i, I don't think the RR was around in 01) . It's kind of a pain to get to as it's somewhat buried but doable if you're handy. Mine would display 0, particularly when it was cold out. Replaced it and it still works fine.
