Digital Speedometer problem
Old Nov 12, 2008 | 12:27 AM
celepano's Avatar
Default Digital Speedometer problem
Hello, I'm new here. can someone help me in my problem regarding my digital speedometer, sometimes it works but sometimes it just reads 0 even though I'm moving. I had it checked in a mechanic and he said that i have to replace the speed sensor. Is there anything i can do or is it just in the wiring? thank you and please email me (celepano@yahoo.com) if you have an answer, thank you.
Old Nov 12, 2008 | 12:38 AM
bigjohnstud4200's Avatar
Default RE: Digital Speedometer problem
do you have a service manual for the bike? If not, you can download one for free.. from where, I don't remember, but if you do a search I'm sure you can find it. Take a look at that. Determine if it's something you think you may be able to do. These jobs are usually easier than you would think.
Old Nov 12, 2008 | 12:44 AM
justasquid's Avatar
What bike is it on? Usually, the speed sensor is located on or near the front drive sprocket cover. It would be a simple unplug and swap sensors.
but before you replace. try cleaning the surface. A lot of times, gunk gets built up on the surface of the sensor and it will work intermittenly or read incorrectly..
Old Nov 12, 2008 | 12:50 AM
celepano's Avatar
Its on my cbr 600f4i 2002 model, the mechanic has cleaned the sensor,it worked but when i went home it started to fail again, is there anything else that i have to check or clean or plug and unplug?
thank you
Old Nov 12, 2008 | 12:55 AM
I can't answer for justasquid but my guess is that you're going to just need to try a replacement and see if it works, it is the lessor of two evils if you are comparing a speed sensor problem to a guage cluster problem.
Old Nov 12, 2008 | 01:01 AM
celepano's Avatar
ok thank you very much, i'll get back on you once the problem has been solved or not
Old May 30, 2012 | 05:59 PM
fryman's Avatar
Check if your sprockets have the same amount of teeth as stock. I heard that can cause this problem. I had the same issue and I bought a chain and sprocket kit with stock gearing, installed it, disconnected then reconnected the battery and haven't had the problem since.
Old May 30, 2012 | 06:22 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
it will usually simply read incorrectly then, off by a certain speed, but it will still read.
if his worked and then didnt after a clean, sounds like something faulty in the wiring or a bad sensor
Old Jun 3, 2012 | 08:18 AM
CBRc5eric's Avatar
I had to replace mine a few years ago (I also have a 01 600, but it's an F4i, I don't think the RR was around in 01) . It's kind of a pain to get to as it's somewhat buried but doable if you're handy. Mine would display 0, particularly when it was cold out. Replaced it and it still works fine.
