Different Exhaust systems
Old Jul 3, 2006 | 04:00 PM
Holden's Avatar
Default Different Exhaust systems
I want a two brothers pipe for my 06 cbr600rr, because they sound and look good, but its also the most expensive pipe ive seen so far. What are all of your preferences for slip ons? or is it worth it to do the whole system?
Old Jul 3, 2006 | 07:44 PM
Tahoe SC's Avatar
Default RE: Different Exhaust systems
different strokes for different folks...
is that a typo or did you say 2 bros is the most expensive? the shouldn't be, there's tons of other pipes that way surpass them quality wise...
now as far as f/s...i wouldn't waste the money on it unless it's going to be a track bike...the gain you get just isn't worth it. also, your lowend will be weaker...even if you tune for it, you won't get it all back, this makes it less than optimal for riding on the streets...you can drop a tooth in the front or put some in the rear to make up for it though.
Old Jul 3, 2006 | 09:48 PM
929 FRB18's Avatar
2 bros exhaust should definatley not be the most expensive, i'm guessing holden is based in the states right? sounds like a pretty aussie name to me. in which case, the exhaust would probably be imported, adding to the cost.
as for full exhaust or slip on, i have a full system on my 929, arrows system, if you want big numbers, full system is the way to go, mine puts out 137rwbhp, exhaust is my only engine mod, may sacrifice a little low end, but its the most rewarding mod. sounds great too
what are you riding?
herbcbr1000f
Jul 22, 2011 08:25 PM
bignibb
Dec 15, 2008 06:01 PM
luminox64
Nov 24, 2008 02:27 PM
Tomek
Oct 5, 2006 05:57 PM
ricksfm
Sep 29, 2005 02:11 PM
