differences from 04-05 to 06-07 1000rr
Old May 14, 2010 | 03:14 PM
skip954's Avatar
Default differences from 04-05 to 06-07 1000rr
what are the differences and what parts will fit. a friend hit a deer awhile back and we ran across an 06 for parts just want to find out what will work before buying a blown motor bike.
Old May 14, 2010 | 03:32 PM
justasquid's Avatar
The only differences that I know of are the upper, mid and side fairings. Everything else will interchange and is the same. The headlights will carry a different part number, but the only difference is the 06-07 has a larger peice of foam on the upper portion of the headlight.. the headlight itself is the same.
The wiring harness may be different though. I think the ECU is different, as well as the 06-07 engine having more compression and slightly different timing.
You could probably mount the 06-07 fairings as long as you have the brackets from the other bike, but not 100 percent sure.
Old May 14, 2010 | 03:55 PM
skip954's Avatar
thanks
what about the motor what will work, motor mount locations (exhaust pc3 ect)
Old May 14, 2010 | 07:53 PM
justasquid's Avatar
As far a I know, the engine external are the same, meaning mount locations, dimensions... ect. they are the same motor, with the 06-07 having a little higher compression. I think they also revamped the cylinder wall material, but other than that, they are the same.
The exhaust is also the same. the only difference is the 06-07 has a slightly different end cap on the muffler.
Old May 15, 2010 | 08:28 AM
skip954's Avatar
ok thanks thats the info i needed hopefully all goes well. after everything is done ill try to get pics up
Deltemis
Mar 24, 2009 04:52 PM
twonis
Sep 6, 2008 08:35 AM
STEVE36
Jul 3, 2006 07:59 PM
yeayea0
Apr 20, 2006 01:26 PM
RC51_SP2
Mar 28, 2005 10:33 PM
