Cutting out intermitently
Old Sep 30, 2010 | 06:41 PM
justasquid's Avatar
Not much to go on. Could be fuel related or gas related.
From the description though, I'd say you may have had water in your gas. When water pools up in the float bowl, it does so right under the main jet. What happens is the water begins to be pulled into the jet, but being heavier, its harder to be sucked up. It then blocks the flow of gas and you get the resultant drop in rpms. The water then falls back into the float bowl, and the cycle starts over again. It was probably eventually sucked up, so the bike began to run fine. At idle, your carbs are using your pilot jet, which is in a different location than the main jet. Probably the reason the bike idled ok, but had issues when running higher rpms.
But just a guess.
cbrdevil32
Mar 9, 2013 09:47 PM
bcouncill
Dec 7, 2008 08:02 AM
dannutz
Mar 19, 2008 01:00 PM
scottisheagle
Nov 30, 2006 06:26 PM
01CBRF4i
Dec 7, 2005 08:05 PM
