Crashed CBR, now need decal stickers...
I laid my 2003 CBR 600 down and scraped the right side of the bike. I'm gonna take the panel off and have it fixed, but the decal stickers need replacing....
I went to the dealer (I live in greece BTW) and they wanted 200 Euros just for the decal stickers....I have never had to buy decal stickers for a bike in the past...but that seems like way to much.
Any place sells them cheaper?
You can find decals on this site in one of the "stickeys". Also you might wanna think about doing all the prep work on the fairing yourself. If its cracked you can fix it with a "fiberglass REPAIR kit" and if its only scratched up a bit then you can use a "FLEXIBLE bumper patch" its kinda like "bondo" but stays flexible so it wont chip off when the plastic flexes. If you want step by step instructions, PM me. You can get it ready to paint for around $30US. Or you can try to find a good used OEM that is the same color either on here in the classifieds or on eBay, I got mine for $60US.
Guest
Posts: n/a
Try http://www.Replicals.com if you want OEM style sticker kits. Can buy them individually as well as in packs if you only want the one side. As for the repair your options are fiberglass like mentioned above, abs repair kits or plastic welding are also options. If you put any filler on it, Evercoat's poly glazes are a good choice. Spendier than normal bondo but has more flex to it and is less likely to crack. I fixed mine ( seriously rashed when I bought it) using fiberglass fiber overlaid with abs glue instead of the fiberglass resin on the back to reinforce a crack or two, then glazed the rash using evercoat. I like using abs glue instead of fiberglass resin since when it dries it has all the same properties of the original abs plastic, with the strength of fiberglass threads mixed in. After I painted them (HVLP gun using Crossfire5.0 urethane enamel) you can't tell there was ever a scratch to it, holding up nicely as well. But to each their own, theres hundreds of ways to fix it.
Theres a ton of tutorials around on the topic, good luck.
I looked at replicals site, and they dont my bike listed.
I couldnt find the stickey on the decals stickers after doing a search.
in fact, i havent even been able to find my decals at all after doing google searches...
2003 CBR 600F. I live in greece, so that makes it a european model, and i dont know if the decals differ for the same year model in the states.
If i have to buy the whole kit i will, but i only need the right side.
Where can i find them???
Scutfargas....
See, it lists CBR 600F4i
Everywhere i look , it lists 600 CBR f4i
i cant find CBR 600F. I'm guessing its because its a european model.
I think im just going to order the CBR decal
http://www.replicals.com/advanced_se...ab4ba1ece0ff68
and then have a graphics/signmaking store make the rest.
