cracked case
Old Dec 30, 2008 | 09:47 PM
got rice's Avatar
Default cracked case
my masterlink broke the chain wadded up and broke some of the case of there are two nipple casting`s that hold the water pump to the side of the block the upper one has a crack in it and now i have an oil leak from the water pump seal going into the block .so my question is am i f***** or can this be welded or am i looking for a new block!
sorry i am talking about a 92 cbr600 f2
Old Dec 30, 2008 | 09:53 PM
thrasher572's Avatar
Default RE: cracked case
Your motor has nipples?
Old Dec 30, 2008 | 10:00 PM
got rice's Avatar
funny
Old Dec 30, 2008 | 10:26 PM
sorry. pics would help
Old Dec 30, 2008 | 11:17 PM
got rice's Avatar
my camra died but the upper piece of case around the front sprocket and the area in front of that where the water pump mounts is the problem area thanks for any info in advance
Old Dec 31, 2008 | 12:12 AM
That doesnt sound good. You may have to pull the water pump off and inspect the area carefully. My concern would be if the crack extends into the bearing race for the transmission output shaft. I had to ****-cana yamaha engine for a crack in that area. If you can get your camera working pics are worth a thousand words.
Old Dec 31, 2008 | 12:18 AM
got rice's Avatar
ill see what i can do about pics and ill pull the pump off and check it closely thanks !
Old Dec 31, 2008 | 04:46 PM
rocketjoe's Avatar
Try some JB weld not the best fix but its cheap and will work for you till you get the funds.
Kolincj
Nov 27, 2019 10:30 AM
Chrisct713
Aug 10, 2010 10:33 AM
cbrtripleblack
Jan 16, 2010 04:14 AM
Investmentmotors
Jun 18, 2006 07:19 PM
rangerbrown
Apr 13, 2006 11:02 PM
