cracked case
cracked case
my masterlink broke the chain wadded up and broke some of the case of there are two nipple casting`s that hold the water pump to the side of the block the upper one has a crack in it and now i have an oil leak from the water pump seal going into the block .so my question is am i f***** or can this be welded or am i looking for a new block!
sorry i am talking about a 92 cbr600 f2
RE: cracked case
That doesnt sound good. You may have to pull the water pump off and inspect the area carefully. My concern would be if the crack extends into the bearing race for the transmission output shaft. I had to ****-cana yamaha engine for a crack in that area. If you can get your camera working pics are worth a thousand words.
