Crack in VSS mount, would you replace?
Old Jan 25, 2021 | 03:57 PM
SunBlue's Avatar
Default Crack in VSS mount, would you replace?
​​​​​​Hi All,
I had a small oil leak from the Vehicle Speed Sensor (2001 F4i)
The sensor itself works fine. But once I removed it, I saw these small cracks in the plastic mount (see pics below)
Not sure if they were there before or happened during removal. It was extremely, extremely hard to remove as the old O-ring had practically welded itself (hard to tell if it was melted or just super compressed) so it could have happened during removal.
Asking for your best judgement. Would you try to fix the crack or replace the whole assembly?
Even though the $$ would hurt, I'm leaning towards replacement for peace of mind but I'm also not sure as the crack seems minor and is not a sealing surface. The last picture is me pushing on the crack as hard as I can with my thumb.
Thanks in advance
Old Jan 25, 2021 | 05:14 PM
74demon's Avatar
Replacement is the best option, but that is not a sealing surface and there are 2 bolts that hold it in so you should be fine. Was it leaking from the seal or was it leaking through the sensor/connector?
Old Jan 25, 2021 | 07:50 PM
SunBlue's Avatar
It looked to me like it was the seal. Not surprising once I saw the condition of the O-ring. Still have to carefully scrape it off the crankcase without dropping pieces in there.
How would you repair it? JB weld or something similar? or just leave it be?
Old Jan 25, 2021 | 08:52 PM
74demon's Avatar
Leave it.
Old Jan 26, 2021 | 05:34 AM
+1 on leave it as it, just check every now and again to see if it gets any worse, the metal bushes will take most of the load from the bolts
Old Jan 26, 2021 | 07:13 PM
SunBlue's Avatar
Thanks guys
ohiophotog
Jul 8, 2024 08:56 PM
Yin-Yang
Apr 26, 2017 11:03 PM
turbo rider
Jun 6, 2016 03:21 AM
nd2slodwn
Nov 5, 2007 03:25 PM
Evan
May 21, 2007 11:01 AM
