Crack in engine case behind stator
Old Nov 1, 2025 | 03:53 PM
Br741113's Avatar
Default Crack in engine case behind stator
Hey guys I have a 2021 cbr600rr and it has a crack that looks like a knife cut right behind the stator on the engine block. It does leak oil slowly and i was wondering if i could get to the inside of the part of the engine without taking the engine out but by taking the stator off? Because I have a buddy that can weld it I can attach some pictures, thanks
Old Feb 21, 2026 | 04:54 AM
sdtsrt's Avatar
f you want to braze aluminium casing or casting you need to take the seals out and put the case in an oven and get it hot otherwise heat will flow away form the weld so fast the casing never get hot enough for the braze to flow to it. Grind the a chamfer on the edges where you are going to weld to make like a valley for the brazing to flow into and use some solvent to clean it well before welding.
Tutuapp 9Apps
Br741113
Nov 2, 2025 05:42 PM
Dazed
Feb 4, 2013 08:20 PM
humboldt racer
Nov 13, 2011 03:45 PM
VALKYIE
Jul 27, 2010 07:27 PM
cbrtripleblack
Dec 16, 2009 10:29 PM
