conversion question !!!!!!!!!!!
i have a 95 f3, its been jetted, p and p, sprockets done (13f 47r) the body is stock, i'm getting ready to swap out gauges for the f4, how much of a pain in the a$$ is t to convert the whole body ( sub frame and all fairs, head light tail light, etc) of a f4 on to a f3? please i really need to know......
I think your gona have to buy an F4. I'm fairly sure they are completely different bikes.
Edit: All the framing is different. And I'm 98% sure the F3 motor wont fit in to a F4 frame.
You need a new frame and subframe. Then your F3 motor wont fit in the F4 frame because they are two different frames. Then you'll have a motorcycle skeleton which wont have a motor in it because you F3 motor wont fit in the F4 frame. No, it is not possible unless you can fab your own custom mounts to screw the plastics in.
