Condensation in the headlights
Old Feb 6, 2006 | 02:40 AM
rookie600rr's Avatar
Default Condensation in the headlights
I noticed that there were condensation/fogging in both headlights after riding today. The weather was warm, and I don't remember this every happening. Do any of you guys have the same problem? I'm sure this isn't normal. It's not serious but it ain't good. Anything I can do to fix it?
Thanks.
Old Feb 6, 2006 | 09:15 AM
doncollins's Avatar
Retired Administrator
Default RE: Condensation in the headlights
I've never had this problem. I noticed that you mods list EuroDezign Blue Xenon Bulbs. Maybe they don't seal as well as the stock H7 bulbs.
Old Feb 7, 2006 | 02:18 PM
richterat83's Avatar
one other option. When you replaced the bulbs, figuring you replaced them yourself, did you put the rubber seal at the back of the housing back on? Not doubting your abilities, just throwing an idea out
My F2 uses H4 bulbs, and, has a rubber boot seal that goes on the back of the headlight housing to seal it off.
Tylor
Old Feb 10, 2006 | 04:26 PM
hyceman's Avatar
ive never touched the lights on my 06rr and all three lights have condensation. ill probably let the dealer know
Old Feb 13, 2006 | 03:16 AM
The rubber seal is in its place. The only other change I've made was adjusted the light housing to shine lower. I didn't have this problem last fall.
Old Feb 16, 2006 | 03:16 PM
drnibor's Avatar
I run my low beam continuously so I don't get any in there cause its nice and warm but I always have condensation in my high beam, I always assumed this was because of the temperature difference between the two and the moist air. When I switch the high beam on for a bit it soon dissapears. How are you running your lights?
Old Feb 16, 2006 | 04:30 PM
rubberband man's Avatar
I have this problem when i ride for a while..... I also never messed with the bulbs but i did take off the front fairing a few times and i think thats when it started happening...
OneWheel929
Jul 5, 2011 05:25 PM
cptspiller
Jun 2, 2007 03:44 PM
1000rrrider
May 6, 2007 07:58 PM
RZRS614
May 2, 2007 12:55 AM
elbaguy
Nov 25, 2006 03:28 AM
