clutch fluid change problem!
Old Sep 1, 2007 | 04:32 PM
rangerscott's Avatar
Default clutch fluid change problem!
I spend $50 on a dam pump bleeder and there isnt an o-ring on the collector can!!!![:@] So I had to go old school and pump the fluid out with the lever. New fluid is in the holder and I'm pumping my hand off and I cant get pressure to build up. I've tried with the lid off and on. What am I doint wrong? I would have thought it would have been just like doing the brakes. Even if air is in the system it should still be able to build pressure and pump it out.
Old Sep 1, 2007 | 07:43 PM
Default RE: clutch fluid change problem!
Got it. Thanks for all the help nobody. [:-][:-][:-] j/k
Old Sep 3, 2007 | 04:32 PM
demonchild's Avatar
Open the bleeder and pump a few times. Then close the bleeder and bleed as normal.
Bordo
Sep 21, 2012 07:33 PM
Hudson
Jun 1, 2012 02:29 PM
raiden
Oct 31, 2010 09:53 PM
Glocker23
Jul 30, 2008 04:23 PM
Anubis
How-To: Mechanical
Jan 16, 2006 02:14 PM
