Changing Sprockets
Old Apr 7, 2006 | 01:07 PM
rrasco's Avatar
Default Changing Sprockets
sorry another noob question.....i keep hearing about changing sprockets to do wheelies. what are the differeneces in sprockets, what are the advantages and why do they give you more power?
Old Apr 7, 2006 | 02:50 PM
ride4sport's Avatar
Default RE: Changing Sprockets
basically you change the sprockets to spin your rear wheel faster, closer to the same rpm coming out of the transmission. dropping teeth on the front sprocket will thus make the front sprocket turn quicker, better acceleration and torque, same goes if you add teeth on the rear.
only negative is that you turn a higher rpm with changed sprockets to do the same speed that you were doing before.
Old Apr 7, 2006 | 04:31 PM
rrasco's Avatar
so you want less teeth on the front and more teeth on the rear?
Old Apr 7, 2006 | 04:51 PM
05Tribal's Avatar
Yes. The typical "kit" for a 600RR will come with a front spocket one tooth smaller then stock and a rear sprocket two teeth bigger then stock and a chain.
Old Apr 8, 2006 | 09:45 AM
Anubis's Avatar
Plus you`ll sacrifice top speed for faster acceleration,
Old Apr 8, 2006 | 02:02 PM
slowpoke's Avatar
Should be about a 10 percent difference with the -1, +2 gearing. If 0-60 time was 4 seconds, it will now be 3.6 seconds. If top speed was 150, will now be 135. If 60 MPH was 5,000 rpm, it will now be 5,500.
BRRandon
Jun 9, 2008 09:28 AM
F4itanner
Mar 7, 2008 11:51 PM
Stockrocket
Feb 18, 2008 05:54 PM
milko
Oct 25, 2006 02:12 AM
mirks
Apr 13, 2006 08:14 PM
