Chain Tension/Headlight Adjust
Old 01-17-2007 | 07:51 PM
Fat Boy's Avatar
Default Chain Tension/Headlight Adjust
Is anyone aware of how to adjust the headlights up on an '04 600rr?
Also, my chain is slightly loose. I generally know how to tighten it, but I am curious if anyone else is comfortable doing it themsleves--mainly, my concern is thatI would tighten the rear wheel on slightly off center, causing problems at high speeds. Any tips at how to get it back on straight? How much torque should i put on the rear axel?
-thanx
Old 01-17-2007 | 09:27 PM
jasonb's Avatar
Default RE: Chain Tension/Headlight Adjust
i know that on my 06 there are 2 philips head screws that u turn one way and the beam should go down.
Or if you turn it the other way it will go up.
as for chain type it in the search see what comes up
Old 01-17-2007 | 10:39 PM
abadfish's Avatar
To adjust the chain:
- loosen rear axle nut
- adjust chain adjusters on both sides of the swingarm
- "lock" chain adjusters
- tighten rear axle nut
this may help with the location of some thing but it may look different on your 04:
http://cbrworld.net/forums/thread/257864.aspx
jamescbr87
05-30-2012 10:59 PM
RDS900RR/95
09-16-2007 09:28 PM
RDS900RR/95
How-To: Mechanical
09-16-2007 09:28 PM
tombooze
03-10-2007 01:24 PM
simo1000rr
10-29-2006 04:15 AM
Quick Reply: Chain Tension/Headlight Adjust
