chain removal
Old 10-30-2005 | 01:15 AM
ryen99's Avatar
Default RE: chain removal
There is no correct way.
It is a tradoff.
Oil works great, actually the manual suggests using 80 weight gear oil or something like that. I don’t use gear oil, because it makes a mess. I will spray WD40 on a rag then wipe off the chain. If you saturate the chain with WD40 I guarantee that after the first ride your whole bike will be lubed.
My steel sprockets and DID X ring chain last about 15,000 miles about 2 sets of tires. I sometimes wipe the chain down with some solvent and a rag. I lube the chain with Wax.
Old 10-30-2005 | 01:22 AM
NINE2NINE's Avatar
Retired Mod
i blow it out with an air hose, clean it with wd40, wipe it clean, let it dry, then apply the chain wax. i do this after riding to let the wax set up before riding and it flings all over the bike.
Old 10-30-2005 | 06:39 AM
Anubis's Avatar
Yeah i spray a rag or similar and wipe it down that way, then you don`t get to much left on to be flung off when you ride.
Omaha rider
07-24-2011 06:18 PM
hypeshipe
03-24-2009 04:51 PM
eekenterprises
01-19-2009 09:05 PM
BRRandoVando
01-07-2009 10:17 PM
Quick Reply: chain removal
