Chain adjuster
Chain adjuster
Hey everyone, need your help with a question. On my 96 f 3 I was replacing my chain and sprockets and rear tire. After reinstalling the back wheel I accidentally broke off the rear lower pin on one of my adjusters for the chain. My question is, can i still use it and be able to adjust the chain tension or do i need to replace. Thanks again.
If you're talking about the part that protrudes up/down from item #7 on this page, then yes you're fine. Those just help located the axle hole so you can put the axle bolt in. It's the axel passing through the swingarm and the adjuster bolt/nut that align the wheel. So, you're fine.
https://www.partzilla.com/catalog/ho...0f3-a/swingarm
