CCT question
CCT question
My bike is an 89, has 25k on it and when it idles it sounds like the bb's in a can just a slight rattling noise from the engine from both the left and right sides, I have been reading a lot of the older posts and it sounds like I have a problem with the CCT, how do I know for sure this is the problem cause it sounds like its a common problem among the bikes, and then where could I get a replacement and how hard is it to replace?
thanks in advance
thanks in advance
Yep. Give it a minute, someone should come in here soon and tell you I'm out of my mind and you should replace it ASAP. Bottom line is nobody has ever been able to show a situation where the cam chain being loose has caused something to not function properly. Sure, it will break eventually, and THEN you should repair it, but there are tales of people putting 10k on a noisy CCT without any other issue.
How do I know for sure this is the problem cause it sounds like its a common problem among the bikes, and then where could I get a replacement and how hard is it to replace?
BTW, see if you can download a service manual (if you don't have one); very helpful: LINK.
thank you very much for the sight but I'm having trouble finding exactly the part I need the diagram shows a few different things, it lists: cam chain, tensioner chain cam, guide cam chain, adjuster cam chain, and theres two different gaskets to choose from
edit: those the right ones?
http://www.ronayers.com/browseparts....e.ronayers.com
viva_brasil
06-09-2008 04:38 AM
