CBR600 ECU Temp senser tech question..
Old May 2, 2006 | 04:16 PM
andygriff's Avatar
Default CBR600 ECU Temp senser tech question..
Hi,
Could anyone please provide me with some info relating to the coolant temp sensor and its related wiring on the CBR600 F4 ?
I need this info to complete the installation of a CBR instrument panel on my project bike. (An 837cc VFR based track bike).
The CBR600 F4 uses a coolant temp sensor which provides engine temperature info to both the fuel injection ECU and the instrument panel.
This sensor has 3 pins, in a triangular arrangement, which according to the Honda wiring schematic should be connected as follows:
GREEN / BLUE – Sensor output to temperature input at instrument panel.
GREEN / ORANGE – To pin 1 of Plug B on the ECU – This looks like the ECU voltage output for the sensor, as it is also connected to the throttle position and MAP sensors.
PINK - To pin 18 of Plug B on the ECU – Which must be the engine temp reference for the fuel injection system. I will not be needing this one as VFR has carbs.
What I need to know is this…
1. Which wire colours connect to which of the 3 pins on the sensor ?
(Sensor viewed end on with single pin at top)
2. What voltage does the Injection ECU feed to the sensor(s) on the Green / Orange wire.
(Some systems like those on BMW’s use only 5 volt sensor supply).
Many thanks in advance,
Andy.
Old May 2, 2006 | 05:31 PM
Tahoe SC's Avatar
Default RE: CBR600 ECU Temp senser tech question..
andy,
go to www.stephygee.com and download the f4i/f4 shop manual. all the information should be there.
t
Royce Dell
Jun 27, 2011 01:55 AM
AREN
Jul 13, 2008 05:13 PM
txn_driver
Jun 30, 2007 11:15 PM
brian t
Jan 26, 2007 02:09 PM
sanders1977
Feb 6, 2006 12:34 PM
