CBR Front Rotor Spec's - Custom Bike Build
Old Apr 8, 2012 | 10:05 PM
neevo's Avatar
New Member
Default CBR Front Rotor Spec's - Custom Bike Build
Hello everyone!
I am customising a Honda CB400F '76 and have chosen to do a modern'ish brake upgrade, mainly driven by the fact a replacement caplier for this bike is horrendously expensive, plus it will look cooler.
I have bought some calipers off a 95-98 CBR F3 and looking to match them up with a pair of rotors.
I am trying to use the stock hubs off the CB400F and machine them a little to accept the rotors so that any future new rotors are bolt on rather than needing machining themselves.
I need help getting a few specs on the Honda rotors, can anyone help or point me in the direction of a good resource?
Looking for:
1. Hub hole diameter
2. Centre to centre hub bolt spacing (opposite sides as I assume all rotors on the CBR's are 6 hole?)
3. Disc offset
Cheers in advance.
Old Apr 8, 2012 | 11:10 PM
neevo's Avatar
New Member
Just measured the stock CB400F hub in case this helps:
Centre hole diameter: 56mm
4 hole pattern (centre to centre): 76mm
Offset: 20mm
entity-unknown
Apr 14, 2015 10:28 AM
toptaz1000rr
Jun 23, 2009 11:25 PM
Tong3
Aug 5, 2005 11:12 AM
