Cbr 600 f4i wont start
Old 05-31-2023, 10:23 AM
Pechal82's Avatar
Default Cbr 600 f4i wont start
I ride a 2006 cbr 600 F4i and the other night bike was running just fine whe i parked it for the night and next morning it would turn over but would never run....fuel pump works and fuses r good and battery is good
Old 05-31-2023, 11:03 AM
dannoxyz's Avatar
Do you have spark?
Old 05-31-2023, 11:40 AM
Pechal82's Avatar
I will check after work today
Old 06-19-2023, 09:58 PM
Pechal82's Avatar
Ok so i checked for spark and i do so next i unhooked the headlights cause they have fans on them that way i could here if fuel pump was coming on and it wasnt....so i replaced the fuel pump and put it all back together and still nothing and the new pump isnt kicking on and all fuses that i can find r good....the relaymakes a clicking noise when key is turned on and i swapped relays as well and did same thing....im stuck
Old 06-20-2023, 12:53 AM
dannoxyz's Avatar
we'll need to start measuring. Otherwise you'll end up replacing your entire EFI system before fixing this.
1. Did you buy brand-new factory OEM fuel-pump assembly from authorised Honda dealer? If not, we'll have to test it to verify it actually works.
2. unplug fuel-pump connector from pump
3. with insulated alligator test-clips, connect one terminal of fuel-pump to battery -neg terminal
4. connect other alligator test-clip to other terminal of pump, making sure it's not touching other clip or terminal
5. touch other end of 2nd test lead to battery +pos terminal
Does fuel-pump run?
Repeat test with original pump. Does that pump run?
The following users liked this post:
rockpool (06-20-2023)
Old 06-20-2023, 06:53 PM
Pechal82's Avatar
I would like to add that the green wire somehow was pulled out from the plug where it connects to wire harness...so i just added little wire to reach other side of plug and connected it directly to the green wire but that didnt fix anything
Old 06-20-2023, 08:55 PM
dannoxyz's Avatar
Well, that properly connects ground to some circuit. Most likely you've got power issue.
Does pump run when you apply power & ground to it directly?
Old 06-21-2023, 07:42 AM
rockpool's Avatar
Ah, so the story really should be "The bike ran fine, then someone messed around with the wiring, and now it doesn't run"...?
Old 06-21-2023, 11:14 AM
Pechal82's Avatar
Im not sure how the wire was cut seeing how its under gas tank and security camaras where i parked it
Old 06-21-2023, 11:15 AM
Pechal82's Avatar
Im not sure how the wire was cut seeing how its under gas tank and security camaras where i parked it....plus i reconnect the wire
Quick Reply: Cbr 600 f4i wont start
