Cbr 600 f4i wont start
Ok so i checked for spark and i do so next i unhooked the headlights cause they have fans on them that way i could here if fuel pump was coming on and it wasnt....so i replaced the fuel pump and put it all back together and still nothing and the new pump isnt kicking on and all fuses that i can find r good....the relaymakes a clicking noise when key is turned on and i swapped relays as well and did same thing....im stuck
we'll need to start measuring. Otherwise you'll end up replacing your entire EFI system before fixing this.
1. Did you buy brand-new factory OEM fuel-pump assembly from authorised Honda dealer? If not, we'll have to test it to verify it actually works.
2. unplug fuel-pump connector from pump
3. with insulated alligator test-clips, connect one terminal of fuel-pump to battery -neg terminal
4. connect other alligator test-clip to other terminal of pump, making sure it's not touching other clip or terminal
5. touch other end of 2nd test lead to battery +pos terminal
Does fuel-pump run?
Repeat test with original pump. Does that pump run?
Does fuel-pump run?
The following users liked this post:
rockpool (06-20-2023)
Ah, so the story really should be "The bike ran fine, then someone messed around with the wiring, and now it doesn't run"...?
