Carbs gunked / fuel in oil / what now?
Hey guys, been a long time since I've been around here, but I need some suggestions to get my old lady back on the road. Here goes...
This all started last fall, I was riding daily but then it started to get cold. The petcock on my bike never worked, so I never turned the fuel off, ever, for 3-4 years. It never caused a problem really because I rode daily, I suppose, but after about 3-5 days sitting with the fuel on, it eventually flooded the carbs, I presume. This one sad day, the bike started up fine, choke on, warming her up. However, the idle never rose above 1200, even after the bike was plenty warm. Take the choke off, it died. So at this point, the bike was running, but would never increase idle over 1200 despite being at operating temp. Obviously, something was wrong. Checking the oil I discovered fuel in the oil. I had purchased a new petcock previous to this, but was waiting to put on my clean fuel tank, filter, fuel lines, etc. My old fuel tank was fiberglass patched to no end. After I discovered the fuel in the oil, I immediately put on the new fuel tank and working petcock to prevent the issue from reoccuring. I changed the oil twice to rid it of fuel. After changing the oil, the bike still had the same issue with the low idle. Although I'd like to think I am, I am not a mechanic...thus I was waiting for someone to help me go through the carbs and within a week or two, the bike wouldn't even start. It would turn over on carb cleaner, but not start on the bike's fuel supply. I attempted to clean the carbs, but I couldn't be sure I did it well enough or correct for that matter. I cleaned the varnish out of the float bowls and soaked all the parts I could remove in carb cleaner. It didn't work. Since then, the bike sat and has not run and I have not had any help with it. It won't even turn over on carb cleaner anymore. Trying to get my dad over to help me (he's actually a mechanic, but also very busy), but that's a push in itself. Obviously, the first step is to ensure the carbs are cleaned right. Any suggestions as to why the bike won't turn over? Other recommendations as to what I need to do to fix her?
Start Simple, work hard.
1) Check and make sure you have a good strong battery. If it isn't firing on carb fluid, then it's not going to start on fuel.
2) make sure your petcock is flowing fuel properly.
3) Pull the carbs and clean the pilot jets throughly. Also inspect the floats and the float needles, as even with a open petcock, the floats should not let more fuel into the bowls than the carb can handle.
Good luck and have fun
When the bike ran at 1200rpms, did it sound normal? Or did it sound like a V-twin. If it sounded muffled and like a twin cyilinder, I would guess you already had a plug fouled, then by running it and trying to start it, the others fouled out as well.
I would first, check the sparkplugs and make sure they are firing. If they are wet, and or the spark is orange like. I would probably replace them. Then, if the bike still doesn't start on its own, ( refrain from using starting fluid), move onto pulling the carbs and fully cleaning them.
