carbs
Old Apr 3, 2008 | 02:47 PM
91600f2's Avatar
Default carbs
so i just bought new carbs, they are identical to mine, excpt for four lines, i dont know where these need to go, my old carbs dont have them. you can see the different in the pictures old carbs is on the right, new is on the left
[IMG]local://upfiles/25056/96D5C8A0A55F463C85C9FC7823B7F5D5.jpg[/IMG]
[IMG]local://upfiles/25056/1D3A996847CF42F9844A8CB73F525E29.jpg[/IMG]
Old Apr 3, 2008 | 03:22 PM
marc0011's Avatar
Default RE: carbs
If I didn't know better, those carbs are for an F3. I know what's going on, your old carbs are for 49 state versions and the new carbs are for California models. Cali models have extra emission crap and those four hoses went into some collection chamber (something like that) back by the fuel pump. I've attached a couple pics to point out what I am talkin about.
Old Apr 3, 2008 | 04:10 PM
91600f2's Avatar
Default RE: carbs
so can i just block off the extra emisions tubes? or do i have to find everything else to use them?
Old Apr 3, 2008 | 04:43 PM
marc0011's Avatar
Default RE: carbs
I don't see why blocking them off would cause problems but I really don't know. In regards to buys the additional stuff... you won't want to do that. I recomend blocking them off and seeing how that works. If it doesn't work, you might want to consider going back to the original set. What was wrong with the original carbs?
Old Apr 3, 2008 | 05:27 PM
91600f2's Avatar
Default RE: carbs
throttle drum snapped
Old Apr 3, 2008 | 07:19 PM
marc0011's Avatar
Default RE: carbs
eehhh... that sucks! I guess you have not other option but to try and plug them off.
Old Apr 3, 2008 | 07:58 PM
91600f2's Avatar
Default RE: carbs
i talked to a guy at a local bike repair shop, he said what i should do, is take the connectors off the carbs, and solder the holes closed, and it will be fine. but plugging them off should be okay
Old Apr 4, 2008 | 01:39 PM
marc0011's Avatar
Default RE: carbs
Good to hear. I've seen some good prices on eBay for Cali type carbs and wondered if plugging them off would modify them as if the carbs were a 49 state type.
Spazbite
Sep 3, 2011 10:12 AM
vettefan
Dec 2, 2006 01:14 AM
vettefan
Dec 1, 2006 10:29 PM
yellow_900_rr
Aug 10, 2006 09:59 PM
