cant get throttle cables on
Old Feb 17, 2009 | 02:51 AM
irocthestreet's Avatar
Default cant get throttle cables on
i had to replace my twist throttle because it was broken. now i cant get the cables back into the new twist throttle. anyway to make more slack? or a short cut to doing it ? its on a 96 cbr. all help is appreciated
Old Feb 17, 2009 | 04:31 AM
camaropower's Avatar
Just curious, what model of cbr is it on?
Old Feb 17, 2009 | 04:56 AM
woot's Avatar
On the F4 there is a threaded part by the twist grip on one of the cables. If you haven't already, tighten it down - it will shorten the length of the cable... giving you more slack. If that doesn't give you enough slack you'll have to go and loosen it under the tank. If that is the case, whoever did it last time didn't set it up nicely.
You should be able to get one side on, twist the throttle the other way firmly - then hook the other side on. I think on the F4 you had to do the front side first.
It is frustrating, but don't force it too much as you can break the plastic clips (i did a long time ago)
Old Feb 17, 2009 | 05:08 AM
pacemaker's Avatar
Its just a matter of following the right route. These are not complete but should give you a bit of a heads up. I'll have another go at trying find some with a bit more detail, no promises now.
Old Feb 17, 2009 | 10:30 AM
Originally Posted by camaropower
just curious, what model of cbr is it on?
96 600
Old Feb 17, 2009 | 10:33 AM
thanks for the help guys. this thing is impossibly hard. i can get one side in but when i do the other side i cant. but i get so freakin close.
l-town
Jun 20, 2014 04:20 PM
letsride
Sep 29, 2013 12:17 AM
zellster
Sep 29, 2010 02:42 AM
JDubF4i520
May 20, 2007 03:40 PM
