Can you help a noob out?
Old Apr 5, 2007 | 09:38 PM
dragonium25's Avatar
Default RE: Can you help a noob out?
Check the spark plugs. Look for rust, especially on the chain, sprockets, axle, etc.
Old Apr 5, 2007 | 09:41 PM
ChrisMcD's Avatar
Retired Admin
My suggestion is to troubleshoot and start with what is easy first.
Is it turning over? Sound like it wants to start but just doesn't fire? If so check to see if it's getting gas.....Start at the tank....then go systematically through each part to see if fuel is passing through. A common problem after sitting is the points in the starter get corrodid(sp) and wont allow the bike to fire. The injectors could be clogged as well check again for fuel passage. If it's turning over just not firing fuel is the most common problem. Have you checked the plugs? Looked for spark? Ect.......
Start there and let me know......
Old Apr 5, 2007 | 09:55 PM
ChrisMcD's Avatar
Retired Admin
http://www.gofastvideo.com/gallery/i...ce-manual.html
Service Manual
Old Apr 6, 2007 | 12:22 AM
transambird_2000's Avatar
don't worry it's a honda. It will start
