Can anyone identify these rotors?
![Question](https://cbrforum.com/forum/images/icons/icon5.gif)
I bought these thinking they would fit my 01 cbr 929 but turns out they are way wrong. Thats what i get for trusting ebay. Anyway, i took it to a shop and they can't identify what bike they belong to. It says MIN. TH. 4.5MM. Can anyone tell me if they recognize them plz.
I just spent 90 minutes on the microfiche and every single Honda sportbike I looked at between '92 to '04 uses six disc bolts to mount to the wheel. The ones in your photos only have five ...
That center design is identical to the CBR1100XX, but that bike doesn't use five mounting bolts either ...
Maybe Canadian models got the five-bolt shaft from Honda. Otherwise, they must be from a different manufacturer ...
BTW, the letters just mean "minimum thickness 4.5 millimeters"
I'd guess Kawasaki Ninja. They have the same basica pattern, a small 5 hole bolt pattern, and about the same offset rotor to mounting surface.
The gsxrs and Yamaha's both have the 5 bolt pattern, however the yamaha uses a larger bolt pattern, and the gsxr's don't have quite as large of an offset as the one you show..
just a guess though. Even if they are from a ninja, It would be nearly impossible to tell which model and year.
But, Here is a picture of a rotor for a ninja 1200, 03-05.... just did quick search on ebay, seems to be awefully close...
