Cable lube ??
Old Sep 3, 2008 | 02:10 PM
willduce's Avatar
Default RE: Cable lube ??
if you can find triflow try that...works real good. or some pb blaster, i dont know whats all available in austrailia
Old Sep 3, 2008 | 03:16 PM
Hurricane rider's Avatar
I typically spray wd40 in first to clean the cable out of any dirt that has accumulated, then I go and spray the chain lube I've got into the cable. works well enough for me.
Old Sep 4, 2008 | 05:14 PM
luaP's Avatar
I use superlube or anything with Teflon in it. it dries dry (does that make sence?) and does not collect any grime. I have been using it on Bicycle brake cable and the chain for years as well as my speedo cable on the motorcycle. I ride an old '93 1000f, Hydrolic clutch so not much experience there though.
Old Sep 4, 2008 | 06:27 PM
egf4998's Avatar
If the chain lube gets too gooey, WD40 should be able to flush it out. WD40 cuts grease better than anything.
Old Sep 7, 2008 | 01:51 AM
YAM93's Avatar
How old are the existing cables ? Do you keep the bike outdoors ? Exposed to any rain / condensation / overnight temperature change / rust getting in those cables ?
I replaced mine recently, were over 10 years old... one was fine but stretched to the max. The other one actually snapped as I removed it (from rusting right in the middle and years of rubbing back and forth had weakened it right in the middle also)
You should consider replacing your cables if they're old. You don't want to be in an accident caused by a cable snapping.
dodger79
May 26, 2013 05:46 PM
Spdyg_AK
How-To: Mechanical
Apr 26, 2012 02:17 PM
shraz
May 11, 2006 12:28 PM
ampakes
Sep 14, 2005 01:33 PM
