bypass side stand switch
Old Jan 14, 2007 | 12:05 AM
dscamry's Avatar
Default bypass side stand switch
i have an 04 f4i stunt verson and im trying to by pass my side stand someont told me to ground the green wire and it would work but it didn't what do i need to do? the is solid green wire and green with white tracer, i have tried looping them grounding both and neither has worked. any elp would be great.
Old Jan 14, 2007 | 01:15 AM
chromehonda954's Avatar
Default RE: bypass side stand switch
i am not an expert on bike repair but i know my cars so if i am thinking straight and there are only two wires there then it would only make sence for the kickstand to either connect the two wires or disconnect the two wires so try that..... let me know how it turns out...
Old Jan 14, 2007 | 11:29 AM
dscamry's Avatar
well they are already disconected so i'll try connecting them again. already did that once but it didn't work, but i was in a rush so.
Old Jan 14, 2007 | 03:01 PM
KingMushroom's Avatar
The stand either closes or opens the circuit, as mentioned above. Looping it should do the trick. If not, disconnect it totally.
Old Jan 16, 2007 | 12:49 AM
Zippy's Avatar
On my 929, the sidestand closes the circuit when it's up. I added a two wire plug connector inline with the wires going to the sidestand. Then I created a jumper plug to plug into that connector, which I use whenever I am running without the sidestand. The jumper plug has the two wires soldered together. Plugging it in simulates having the sidestand mounted and in the up position.
rehed
Jun 15, 2013 05:55 PM
JLAvila
Jun 8, 2013 07:07 PM
CalKirley
F2 Tech
Apr 9, 2013 12:54 AM
newnut
Sep 26, 2008 08:45 PM
gregtutch
Aug 23, 2008 07:53 AM
