bypass side stand switch
i have an 04 f4i stunt verson and im trying to by pass my side stand someont told me to ground the green wire and it would work but it didn't what do i need to do? the is solid green wire and green with white tracer, i have tried looping them grounding both and neither has worked. any elp would be great.
i am not an expert on bike repair but i know my cars so if i am thinking straight and there are only two wires there then it would only make sence for the kickstand to either connect the two wires or disconnect the two wires so try that..... let me know how it turns out...
On my 929, the sidestand closes the circuit when it's up. I added a two wire plug connector inline with the wires going to the sidestand. Then I created a jumper plug to plug into that connector, which I use whenever I am running without the sidestand. The jumper plug has the two wires soldered together. Plugging it in simulates having the sidestand mounted and in the up position.
