Brake Lines
Old Apr 13, 2007 | 02:27 PM
cwmc29's Avatar
Default Brake Lines
Can someone tell me the difference between steel braided brake lines and kevlar brake lines. What is better and why.
Thanks
Old Apr 13, 2007 | 03:03 PM
jbreit's Avatar
Default RE: Brake Lines
Both are reinforcement material over the true fluid carrying hose. Their job is to restrict swelling of the hose when you apply pressureto the brake lever. This swelling effect can become pretty bad in a rubber hose as the brake system gets hotter during hard use.
Because of this improved resistance to swelling, more of the effort you put into the brake handle translates into stopping force....improved brake feel.
Kevlar stretches less for a given amount of pressure than stainless braiding....so you couldsay its "better".
Stainless lines are very good too....I like the black vinyl coated stainless line better than the ones inside a clear vinyl tube. The clear vinyl yellows and is stiffer and bulkier.
I've had both, but never on the same bike....so can't give a fair comparison. Nor can I say my abilities are good enough to even give then such a comparison.
Old Apr 13, 2007 | 04:42 PM
Tahoe SC's Avatar
great explanation mang!
kevlar is more pimp i think cause they come in fancy colors. both will wear over time...i always thought that kevlar gave a bit more than ss...or vice versa...i can't remember. both will be awesome!!!!!!!!!!!!!!
DRam
May 31, 2014 05:52 PM
cycle.tim
Jun 11, 2012 05:36 PM
f3racer
Jan 4, 2008 10:51 AM
traitorhound
Feb 20, 2006 07:30 PM
