blowin smoke
Old Mar 20, 2008 | 02:22 PM
mcwheelie08's Avatar
Default blowin smoke
hey all you die hard honda fans !!!! hope someone has some insight for me . my last 8 bikes were honda cbrs i am currently bangin my head off of a 05 1000 and it is an oil burning pig about 1 quart every 1000 miles blows blue smoke on decel and only has 4000 miles on it!!!! any suggestions????
Old Mar 20, 2008 | 03:08 PM
Nauree's Avatar
Default RE: blowin smoke
Your leaking oil inside your motor. Your gona have to take the motor apart and replace the gasket thats leaking.
Old Mar 20, 2008 | 03:14 PM
Lrn2Go's Avatar
Man, I would only hope with 4K miles that you'd have some kinda warranty on the beast. If not... then sadly, yes, Nauree is right. Oil is getting into the combustion chamber... and if at a quart ever 1K miles, it's practically drinking the stuff in my book! I'm trying to remember what gaskets are effected primarily on Decel (since that's where you notice the smoke the most), but it's not coming to me. I lean towards potentially piston rings, but with such low miles, and without the "puff" that comes when you hammer the gas ON, I'm not convinced. I might tend to lean closer to the Valve guide seals going bad... that low of miles is just gettin' me though! (thing either just got a lemon part, or it's been neglected/hammered? Could be either way)
Old Mar 20, 2008 | 03:44 PM
yeah i had a warranty it was 12 months unlimited miles it started doin it after my 12 months was up so i havent been ridin it much for fear of doin more damage the oil was changed at 600 miles and then about every 1500 miles using nothing but the best honda oil at 9 bucks a quart which is a major rip off and my buddy has the same bike with a little more miles doin the same thing. its kindas startin to **** me off considering i bought my last 3 bikes from this dealer and they wont help out with the repairs
Old Mar 20, 2008 | 03:50 PM
Bumble Bee's Avatar
You and your buddy need to find out to the area Honda rep is and contact him. If both your bikes are doing it then others have to be as well. That is very low miles to have a problem. My 2000 F4 with 29Kdoes not even smoke or burn oil.
Old Mar 20, 2008 | 03:54 PM
any body have any idea what kinda cost im lookin at for me to pull and tear down this motor and replace rings and how bout some cheap upgrades while im in there
Old Mar 20, 2008 | 03:55 PM
Lrn2Go's Avatar
Nearly 11K miles on my 07 600, no smoking, no burning, runs like the day I bought her.... (well, if you were to take away all the "fun" mods.)
Old Mar 20, 2008 | 07:34 PM
TK954RR's Avatar
Jan 2009 ROTM
Wish i was a motorcycle tech. Umm is there a lot of oil in your air filter box? Could be pulling too much out of your valve cover, that could be more minor. Also and maybe some one could correct me if im wrong, but dont these have valve guide seals? If you have a blown one that would be considered a much more minor fix for ya. Wish i knew more, but best of luck to ya.
Old Mar 20, 2008 | 07:47 PM
Nauree's Avatar
Anything requireing the motor to be pulled is automaticly a few hundred dollars just to pull and find the problem.
Old Mar 21, 2008 | 06:47 AM
fishfryer527's Avatar
do a compression check and a leakdown check justto get more info to post for all the smart people that read these posts.
But I think you may have one or more bad valve seals, maybe not rings.
