Bleeding fluid gizmos
Old Feb 16, 2006 | 06:28 AM
Anubis's Avatar
Default RE: Bleeding fluid gizmos
I used the Mityvac recently to, pretty straight forward.
Old Apr 9, 2007 | 11:15 PM
Jaybird180's Avatar
I found the Motion Pro easy to use. Now I've got new lines. Will this prime them?
Old Apr 9, 2007 | 11:17 PM
Jaybird180's Avatar
Just checked their website, which says it will not bleed air from a dry system.
Old Apr 10, 2007 | 12:21 AM
pacemaker's Avatar
Bleed kits are for cars, (unless you have someone pumping the brakes that's telepathic). Clean glass coffee jar & clear plastic tube, is all you need.
Old Apr 10, 2007 | 01:59 PM
Tahoe SC's Avatar
if you're swapping ss lines or something...where you will need to get air into the system, will definitely have to go with a mity vac...or else you'll be pumping 20000 times to build enough pressure to prime the lines. then another 20000 to get all the bubbles out.
Juliet
Nov 6, 2019 08:29 AM
Juliet
Stickies
Jun 1, 2010 10:22 AM
Juliet
May 5, 2010 01:45 PM
wolfy01
Mar 18, 2009 04:30 AM
Ricepowered01
Oct 26, 2005 12:02 PM
