bleeding brake problem
Old Jul 21, 2009 | 01:03 PM
westwood600rr's Avatar
Default bleeding brake problem
ok here is the scoop, I like a dumb-*** left my brake lock on and started to ride off. Yes got about half of a revolution on the front wheel and it slammed into my brake. Yes like I said dumb.... I removed the brake and inspected rotor no visible damage. While the caliper was off I checked to see if the brake worked it was fine. I have no pressure in the system and after bleeding brakes twice I still cant hold pressure. It stays for a second then as I roll it forward it goes to ****. any help would be great. Also Ive gone to a couple shops in the area and none seem worth a **** anybody have a good line on a shop?
Old Jul 23, 2009 | 03:11 PM
Todd84's Avatar
The rotor is bent. I bet you a dollar you get a new rotor and it will be fine. Rotors are expensive so I would take the rotor off and have it checked. Set it on a flat surface (granite table, countertop) and check with feeler gages. Cause if you buy one and don't need it my dollar won't cover it.
Oh and ask me how I know........ LOL Don't feel bad it happens
Old Jul 28, 2009 | 07:03 PM
sbf916's Avatar
id put my money on the rotor too, unless ur calipers or master cylinder's leaking thats the only thing that would cause a total loss feeling once u roll the front wheel.
Old Jul 29, 2009 | 02:38 AM
pacemaker's Avatar
Mate, I don't have enough fingers to count how many people I know that have done the same or similar thing with disc brake locks, chains & cables (some still attached to poles). I think some of the disc lock manufacturers actually give you some luridly bright thingo to go with your keys so you get a reminder.
switched
F2 Tech
Nov 20, 2010 09:27 PM
Black Rider
Nov 1, 2009 06:09 PM
WildWill
Feb 18, 2009 05:30 AM
TennesseeCBRF2
Sep 30, 2006 12:06 AM
Err
Sep 13, 2006 10:07 PM
