blade speedo/instrument, NO GO !!
hello guys.
can anyone help, i have a 2002 blade. on the speedo/instument panel. the only thing showing is the neutral light when ignition is switched on, also the light is ok when turned on, i have no speedo, no tacho , no mileage counter. HELP!!
my speedo on my f4i does the same thing have a wire that got cut when dropped /and check the speedo fuse if you have no because i can take my fuse out and the n light will still come on
