Bike wont stay in second gear
I have a 2007 600rr with 24k miles on it. I purchased it a few months ago from someone and since I owned it the bike when shifted into second stays there until around 5k rpm or if I just keep it there for a period of time like 3k rpm for 1/4 mile it slips out and goes to neutral. The clutch is new the bike rides great in every other gear even 6th.
From reading it sounds like a bent shift fork. I need pointed in the right direction to identify if this is it. I hear mixed stories that I have to pull the engine takes the heads off etc. to see if they are bent.
I am mechanically inclined with cars, I have not dug that deep into a bike before. if anyone can shed some light on this that would be great.
Thanks
Thanks
Thanks
Thanks
Last edited by highwaypatrol; Jul 14, 2013 at 01:55 PM. Reason: Added information previously left out.
The symptoms you are describing, sounds like you have a worn out second gear dog bones. a bent shift shaft will have difficulty selecting a gear or not able to at all. a worn out gear will pop out under hard acceleration into a false neutral. A bent shift shaft is mostly caused by a bad gear popping out. If you want to check the shift shaft, remove the clutch cover, clutch and the gear selector. the shaft should be 90 degrees from the actual selector.
The person I purchased it from said he had the clutch, chain, and rear sprocket replaced and has about 1500 miles on it. The clutch cable screw on the handle bars is screwed all the way in which usually means the clutch its nice and tight and good. I do not have any trouble shifting into ANY gears. I got my hayns manual in and Boy checking/replacing those shift forks is a complete tear down of everything taking the motor down to bare bones.
I will get the cover off and use the hayns manual to inspect the gears hopefully the guy just lied to me or the shop didn't install it right.
Having a bad clutch wouldn't cause the bike to slip out of gear just be hard to get it into gear and would slip under acceleration, pooping out is prob either a bad gear or dog and unless you heard that gear grinding a lot from miss shifting or somethin I would say the dog
What part is the "Dog" ? same process as the shift forks? Where I would have to go in through the motor, or is the "dog" something i can get to by taking the transmission apart the gears and all that?
The "dog bone" or dog gear is gears that interconnect gears in the transmission, your shift fork is what slides the gear to lock with its mate gear. I believe second mates to 6th. When this wears down causing the gears to grind wearing the teeth smooth. The fork will then get bent from the force of the gear pushing back when it slips out. This then could damage, shift shaft and the shift drum. Replacing the gear usually requires spliting the case, but I'm unfamiliar with your bike.
The only way to really know what's damaged is to take it apart and look but typically a second gear repair means
New second gear and 6th
New shift fork
And shift drum and shift shaft if needed.
New shift fork
